Heres the problem. I broke the C channel in the back and pinched my gas lines, but still ran fine. I had it repaired like a week later and about a week later I pulled up to my house and the car kept shutting off, and then just died about 4 hours later. It wont turn over for anything. I have changed: Distibuter, spak plug wires, checked fuel delivery, checked computer and it said it was the ECM but we changed it and didnt change anything. when I try to start it alls it does is turn and hits like its tryin to start and even backfires. I am clueless, the next thing is to change the rubber gas lines in the rear because they are bent from the c-channel being on them. If anyone has been through anything similar all help is appreciated.
Originally posted by 84caddy@Dec 18 2003, 12:15 PM
are you getting power to the fuel pump? If you put some gas in the TB will it run for a second then die?
could've either messed up a power line or ground to the fuel pump in the tank, or you have a bad oil pressure switch (which'll cut power to the fuel pump)
Its pumping fuel to the TB but I'm not getting that mist of spray from the TB.
The car may have jumped timing or the throttle bodies injectors arent any good they may not be getting power
