1 - 13 of 13 Posts
Wassup out dea,maybe someone has had this happen to them. Went to go start up da ride the other day. Did the norm to start it,turn key and nothing on the digital cluster came on. Was checking fuses but haven't seen anythang blown. Is there any relays for the cluster. If the digital dash is bad, is there any spot that can fix it. Dont want to put another one from a junk yard that might have a gang of miles on the odometer.
:cool: Thanx for tha info
I can sell you one Cheap :biggrin: LMK
since this is digital, i thought that the mileage stayed in the computer of the car so no matter what dash you use it would always show the mileage on YOUR car and not whats on the used dash......i might be wrong
there's a module in the digital display cluster for the odometer. that's where the mileage is stored, not the ecm
I had a 95 Deville with the same problem. It was just a loose connection behind the display. Hope yours is that simple :)
when i bought my 95 caprice it was out, i took the lens and digital screen out, cleaned the backside of it and tweaked the contacts it rests against towards it for a better connection, put it together and it worked forever after. it doesnt actually plug in, when you screw the screen down it simply pushes against the metal contacts, years of potholes etc create a small gap and let dust in breaking the connection.
of course it could be fried and need rebuilding but trying to do this repair will just cost you a little time.
1 - 13 of 13 Posts
