1 - 17 of 17 Posts
New washers, tighten.
if your brake line are flipped over on the caliper they will leak. i went thru this. tighten bolt so much that is rounded it off, still leaked, had to use vise grips. couldnt figure out why it leaks. flipped over the hose so the other surface is on the caliper and tighten a new bolt with minimal effort and no more leak. and as state above u need copper washer on each side of the bolt, dont double stack the washers. no thread sealant.
1 - 17 of 17 Posts
