Auto Zone or Advance Auto has diagrams plus they are in the Chilton books
what do you need? the firing order? Im sure someone on here knows that :). if not, I could get you a diagram on monday if it can wait that long.
ok i can tell you how to do it
1. take the number one plug out witch is on the left side of the engine at the front
2.take a small screw drive put it stright in the spark plug hole
3.put a ratchit and socket on you bolt on your bottom pully
4.turn the engine over very very slow antell the piston toutches the screwdriver and then stop if you go to fast you can bend the screw driver or bust a piston when you fill it barley toutch it stop
5.then take off the cab witch ever way your rotor bug is pointing (you can tell buy the small pice of metal sticking out) that is going to be your number one plug
7.then you hook all the plugs wires in to the distributer cap
8.your plugs on the block on the left side are 1.3.5.7 on the right side it is 2.4.6.8 once wires are on the cap the wires go like so
1.8.4.3.6.5.7.2
the most you could be is 180out but i dought that is the case if you did not pull the whole distributer out of the block
i hope tis helpsif you have any quistions pm me i cant tell it a little better
if any one wants to tell me this dont work i just did my engine and it fired the first time with out any problem
