i want to get some of the rust off of my LAC which do i need and where do i get one from.
if your asking this question you probably want to leave it alone because you will make it alot worse....and depending on how severe/deep the rust is you will probably have to sandblast...
To get the rust off you need to cut it out, weld in a new piece of metal, cut it down to size, grind the weld, primer it, sand, primer again, wet sand and paint is the best way to take care of it
i know of some people that use lead as body filler....it depends on how deep the rust is set in though...typically they only do this around the windshield and areas where putting new metal in will be difficult
