1 - 10 of 10 Posts
No, Run a one channel amp with no divider, it's proven to be louder than with a divider, the 2 subs will act as one. but never run more than one channel without a divider!!!!
You know, I wish the search feature on this site were working, as I've covered this several times.
Are you talking sealed box or ported box?
Subs recieving exact same signal?
SPL oriented install?
Pressed for space?
Basically, single and common chamber enclosures both have their own pro's and cons. Which is better in your situation depends on the above as well as a few other factors.
Pressed for space?
:ugh: :ugh: :ugh: :ugh: 2 12" Concepts.
In my trunk of my droptop
Single amp for both subs
Sealed box.
Sub box will be 33x13 deep x 14.5 tall.
Subs need 1.0 to 1.8 cubic ft. per sub. :biggrin:
Originally posted by DownLow350+Jan 16 2004, 03:36 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (DownLow350 @ Jan 16 2004, 03:36 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--JeremyD@Jan 16 2004, 02:29 PM
Pressed for space?
Sealed box.
Subs need 1.0 to 1.8 cubic ft. per sub. :biggrin:[/b][/quote]
I'm by far no expert, but with the single amps, I would run the divider ;)
in just a normal shaped (square rectangle wedge,etc) just stick one in there for support.
but I've got 3 subs running common chamber in my truck right now.it doesnt matter if your subs are ran mono.just for extra bracing mainly.
also, if you have to use a temporary setup where you can only run one sub at a time,then a divider is good.
1 - 10 of 10 Posts
