Well then, someone mentioned about my signature not adding up. This is perfectly explainable. First off, 2 orion 1200d's strapped means, that the 1200d's will do around 2.5kw at 2 ohms. I have a Type R sub dual 2 ohm to be specific. The woofer is wired to one ohm to both amps, yes i am running these amps below recomended resistance measures. So, the 1200d's will do 2.5kw at 2 ohms, i wonder what they are doing at 1 ohm.
. I know this may seem like alot of power for a little 500 wrms woofer, but my friends have done extensive testing on the Termlab sensor. Not only does the new 05 type R handle power better than an RE SX for burps and music, but it sounds way better. Your competition box is your daily box aswell for this woofer as it will tend to peak in between 40 and 50 hz. yes, that is low, which mean tuning would probably be around the 30-35 hz range for the box. yes, the type R is louder at a lower frequency than the SX at a higher frequency. The SX is a fart woofer, not as musical as the type R, so it will peak at a higher frequency around 60 hz or so. well now i am rambling on and on, the truth is, the new type R is better than everyone thinks. My buddy ran high 151's with a single type R 12 out of the trunk of his monte carlo, at the kick, MECA style, on his very own termlab usb.
wow, block stylie owns me.
al
al
