1 - 3 of 3 Posts
Phoenix Chapter President
If you have the old Roadstar Rims and have the adapters but the bolt pattern wont fit your ride, look no further, there's a machine shop in Mesa,Az that will drill them any bolt pattern as long as the bolt pattern is in the demension of the adapter,My USO hooked me up with Mike at the shop(Mesa Steel & Machining).Its Pricey though,$80 for each adapter drilled or $125 each adapter and Hub(if there 72 spoke roadstars the hub needs to be drilled but if there 100 spokes no need for the hub to be drilled since the hub is bigger)................Im sure most machine shops close to where you live can offer the same............Just some FYI.......
i know where some 4 lug roadstars are anyway to make those into 5 lug to fit a regal?
1 - 3 of 3 Posts
