the driveline is being pushed forward when i go up with the hydraulics in the back pushing the tranny up and causing problems with the throttle does anybody know how i can fix this problem thanks IMPALA 67
slip shaft from blackmagichydros
how long your stroke and and coil size
There's 2 options, either you install a 2 piece driveshaft with a slip yoke and carrier bearing, or you give Black Magic Hydraulics a call and get their new Slip shaft that dosent need a carrier... ;)
Either shorten the driveline or get a slip shaft installed in your driveline
will i need aq slip shaft on a basic setup on a 64 impala with 8 in front and 10 in back
Not really, but it's way cleaner, you will fuck up your carrier bearing after a little while if you don't run a slip. If you run shocks in the back, you won't get out more than like 8", even with a minimum of coil.
