OK the 3'8 is only available in single port , simple enough
the 1/2 inch is dual port, how do i plumb that up , i have eight vavles right now. DO i just plug the one port off, or is one for air in, and the other for air out? or are they both air in, adn i need 2 more valves or are they both air in, and i tee one valve?
mine is just one in and one out
on in and one out runs pretty good i have it on the towncar its the same as single port tee'd i guess if you were gonna hop it then both would be used for in
Dual ports are a bit over rated as it does not make much diffrence if you have one for fill and one for dump, it may make a diffrence if it was 3/4 line and valves and simply for hopping but not much else!.
