1 - 13 of 13 Posts
I was wonderin if anyone has hacked into one of these yet... If so Post some pix!!!! I have some wicked ideas for mine, but untill I get my hands on a dremel, I cant do shit...
No one has ever modified a dub impala???
I knew that... I just wanted to see if any one had actually done it, or if I was gonna be one of the first...
I also am working on one although it is not the impala its a surburban.I haven't worked on the body yet but i have work on the interior remove the body kit and the first thing i did was change the rims.
Cut the trunk, hinge it, and move the subs to the trunk.
yo.. try to cut it from inside out man..
not cut it all the way.. but slightly let the dremel cutting disc glide onto the inside surface..
and when you think it's thin enuff...
you slowly prees it in...
this work method prevent your trunk being bad cut..trust me.. been there done.. that.. it costs me another die cast... sniff sniff..
but from mistake you will learn...
and... you should have a mini welding torch..... CAREFUL OKAY.. this kinda work must be supervised under an adult eye..so let your dad do this...
or else.. some one has to call 9-1-1- madd quick...
good luck...
1 - 13 of 13 Posts
