1 - 20 of 38 Posts
You guy's talk about adex, squares, italians for hopping
what's the difference between these dumps and the
delta ones that come with a kit don't they all do the same thing
dump the oil back in the tank. I know this might be a stupid
question but I don't know my ride has delta's and I don't
have to many problems with them besides a o-ring here and there.
:cool: :cool: :cool:
For the most part, Delta-type dumps are just as good as the others. The problem is that the internal cartridge (and sometimes the bodies) can't handle some of the serious back-pressure that's applied to them when doing major hopping. It's almost like having a garden hose hooked up to a fire extinguisher. It will work, but it's not the best thing to use in that particular application.
But don't get me wrong... I love 'em. I've been using the same 8 Delta's for the past 12 years. No problems with them yet. Just change the o-rings every 18 months. ...But I'm not a hopper either.
with my deltas im good if i dont hop but as soon as i start hopping they start to stick with in a week i say DELTAS SUCK
well i never had them stick and my car does hop
not as much as i would like on a 48 volt setup
and i am not interested in adding more batts.
i had this setup installed about 8 years ago
and iv'e been tweeking it a little each year
springs gearheads i wonder if i get better dumps i will
get some more inches. here is my set up.
:dunno: maybe you just have good luck :biggrin: i hate them im going with italian dumps now
krewl i like thise deltas ,i havent even had a leak,let alone havem stick , i didnt even know they stick!! i can get 20 inches at least . ive got a set of the exact same pumps prohopper,their in the cut for now, im rockin reds stylin pumps i dunno what kind dumps r in em but they work well too i hopp a lot too.... ;) ,krewl
It has been known to gain inches by changing only the dumps to adex dumps....
You'll get more flow with an adex compared to a delta, of course you can always plumb out the dump on the pressure side... and then t off back through the dump... people even do that with adexs, just plug of the port...
Originally posted by Volv_lo+Dec 11 2003, 11:23 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Volv_lo @ Dec 11 2003, 11:23 AM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--smkweeddaily@Dec 11 2003, 09:45 AM
You'll get more flow with an adex compared to a delta, of course you can always plumb out the dump on the pressure side... and then t off back through the dump... people even do that with adexs, just plug of the port...[/b][/quote]
:confused: Can you explain that
Yeah I guess that is confusing...
From the pump, run the line after the check valve to the cylinder, then t-off from that line and install your dump, plug off the pressure port in the dump......
that way you can not be restricted on pressure and still dump....
Originally posted by junglejorge+Dec 11 2003, 10:34 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (junglejorge @ Dec 11 2003, 10:34 AM)</td></tr><tr><td id='QUOTE'>
:confused: Can you explain that[/b][/quote]
i think he means running a strait hose from pump to cylinder and "t" the line and put the dump on the "t" and block off one side
so insted of fluid going through the dump then to cylinder
it will go strait to cylinder and the dump will be out of the way
Originally posted by joebomber52+Dec 11 2003, 10:41 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (joebomber52 @ Dec 11 2003, 10:41 AM)</td></tr><tr><td id='QUOTE'>
it will go strait to cylinder and the dump will be out of the way[/b][/quote]
yep thats what i mean
Originally posted by joebomber52+Dec 11 2003, 11:41 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (joebomber52 @ Dec 11 2003, 11:41 AM)</td></tr><tr><td id='QUOTE'>
Thats what the OGs call a freeway.
1 - 20 of 38 Posts
