Ok, heres the low down... bagging a '97 Integra, found a "complete kit" from EasyStreet here:
http://www.easystreetair.com/index.asp?Pag...PROD&ProdID=680
The EasyStreet price for the kit $2,175.00 which includes:
?.... Are the "Air Struts" the same thing as the "Airlift Sleeve w/ Bag 1/2" Port"?
Why is it's 2x's the price and is there anything that i'm missing?
Thanks all again for the help!
So I went to suicidedoors.com and they have the SAME AirLift brand parts (also known as EasyStreet) for the following prices:- 2 Front 9-way dampening Air Struts
- 2 Rear 9-way dampening Air Struts
- 8 of our 3/8" exclusive chrome 300 PSI Valves
- Viair 380C Chrome Compressor
- 5 Gallon D.O.T. Approved Air Tank with 8 1/2" Ports
- 2 200 PSI Dual Needle Gauges with Chrome Bezels
- 40' of 1/2" D.O.T. Approved Air Line
- Nickel plated D.O.T. push to connect fittings
- 145-175 PSI Pressure Switch
- 4 Switches
- 50' of 1/4" D.O.T. Approved Air Line for your Gauges
- 90' of 16 Gauge Wire for Proper Valve Connections
?.... What are the "Push to connect fittings"? and how much are they?...................................................................................$$
- 2 Front 9-way dampening Air Struts.............................?
- 2 Rear 9-way dampening Air Struts..............................?
- 8 of our 3/8" exclusive chrome 300 PSI Valves.............280.00
- Viair 380C Chrome Compressor..................................185.00
- 5 Gallon D.O.T. Approved Air Tank with 8 1/2" Ports.......56.00
- 2 200 PSI Dual Needle Gauges with Chrome Bezels........60.00
- 40' of 1/2" D.O.T. Approved Air Line..............................30.00
- Nickel plated D.O.T. push to connect fittings....................?
- 145-175 PSI Pressure Switch........................................16.00
- 4 Switches...................................................................20.00
- 50' of 1/4" D.O.T. Approved Air Line for your Gauges......10.00
- 90' of 16 Gauge Wire for Proper Valve Connections.........5.00
SUB Total.......................................................................662.00
