1 - 2 of 2 Posts
[h=4]https://www.amazon.com/dp/B01DJ54LAC
License plate flipper — is a rotating plate. If you have 2 plates — you don’t have to change them with a screwdriver. Press the button and plates will be changed. Installation doesn’t require cutting the bumper or the body of the car. Mechanism is hidden behind replaceable panel.[/h][h=4]Specifications:[/h][h=4]Material of construction: metal[/h][h=4]Case Size: 18x33x2 inch[/h][h=4]Inner size: 30×15 cm[/h][h=4]Frame supply voltage: 12 V[/h][h=4]Color — black[/h][h=4]Options:[/h][h=4]1 plate[/h][h=4]1 button control[/h][h=4]As soon as you press the button, the plate is flipped 180 degrees so one plate is replaced by another. The entire construction of the device is made of a metal, which complicates dismantling of the plate. The construction is designed in such a way that it can work even when fully submerged in water. Such device is used if the car officially uses 2 license plates. Important! This function is only valid in the countries where it is allowed by law.[/h][h=4]Installation and Operation:[/h][h=4]The plate requires periodic maintenance — lubrication of rubbing parts once a month in summer and 2 times a month in winter (or more — depending on operating conditions).Before installation, lubricate the drive cable oil (shed from the motor side).[/h] $_3.JPG $_3 (1).JPG $_3 (2).JPG 5cdd53fe5110.jpg
1 - 2 of 2 Posts
