1 - 5 of 5 Posts
Corrosion on battery terminals (remove terminals and clean)
Bad ground on battery to frame/body...
Bad ground from motor to frame/body...
Bad ground on the h/u...
Bad ground on the amp...
Cheap or bad amp...
Bad alt...
Fouled or cheap non resistor type spark plugs...
Cheap or cracked spark plug wires...
Cheap RCA cables, bad RCA cables (replace with higher quality)
RCA's run along side of power wire...
You could also look at the pinned topic for answers before posting... ;)
http://www.layitlow.com/forums/index.php?s...dpost&p=5671112
1 - 5 of 5 Posts
