and what kind of coats should I use...
primer first and then spray the paint?
Any help is greatly appreciated... :cool:
Originally posted by TheGODFATHER@Dec 12 2003, 09:58 AM
Make sure you get the engine really clean Degreaser, Sand blast the block if possible. What kind of paint are you shootin'???
What do you recommend?
i would powder coat. then of coarse what color.
Originally posted by Talkn+Dec 12 2003, 05:31 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Talkn @ Dec 12 2003, 05:31 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--TheGODFATHER@Dec 12 2003, 09:58 AM
What do you recommend?[/b][/quote]
As long as you Prep the Block real good it shouldn't matter what kind of paint you use. (No Spray cans) It just depends on what you want your engine to look like. Kandy, Base-Coat whatever you want. I've always thought just a House of Kolor Orion Silver Base with Clearcoat over it would make the engine stand out more than anything. Plus if you ever repaint your car you won't have to change the color of the engine to match. ;)
SEAL IT...WITH ETCHING PRIMER SO IT STICKS GOOD,,,,,OR USE DP90 PPG SEALER....CAUSE YOU DON'T NEED YOUR SHIT TO BE FLAKING OFF
