1 - 15 of 15 Posts
check this out i got a 4.3 v6 carb motor in my 1996 s10 someone put in. trys to start kinda has spark and its gettin gas but wont go what u think could be problem i think either timing off no compression or i need a new module what u guys think help me out
move your wires on the cap one stud and see what happens. check and make sure your not getting too much gas and its flooding. i had to do both and get a fuel return line to the tank unplugged to get mine to run right.
TDMMC
If you are getting fuel and (kinda spark) you might have something as a bad connention.Double check youre coil wire.Is it a Vortec?
Triple OG
Originally posted by ALIAS@Sep 18 2005, 10:38 PM~3840676
no its not a vortec no i ment on their it kinda trys to start it has spark
where are you from? is it getting cold? It could be the choke is bad or out of adjustment.
check the starter ... i had what i thought was a good cranking speed ... spark air fuel ... a can of either ...
i ended up pulling the starter ...(after serveral jumps startsthat still didnt light it )
and one of the brush wires had fell off resulting in me getting a new starter
Originally posted by pink63impala@Sep 20 2005, 01:39 PM~3849920
TOUCH YOUR FINGER IN THE PLUG,AND HAVE SOMEONE TURN IT OVER, IF IT HURTS REALY BAD, YOUR GETTING GOOD SPARK :0
when your whole hand feels it. you KNOW its good :cool:
If you are going to do that, just touch with 1 hand from the wire to ground. Dont risk it going thru ur heart. Not enough to kill you but.....
Doesnt really work cuz u dont know the diff between 5kv or 10kv.
Check if you got compression.
Originally posted by pink63impala@Sep 24 2005, 12:26 AM~3875184
its really good when it knocks you down on your ass.me, i sont even fuck with that!nothing scares me more than electricity :biggrin:
one time i got shocked from my ignition key when i went to start my car while it was getting jumped. THAT sucked.
1 - 15 of 15 Posts
