1 - 14 of 14 Posts
i changed my spark plugs and wires and it feels like my engine is riding rougher, vehicle shakes at idle in park and when i accelerate, all the wires ARE hook up to the right coils, and the plugs are the right plugs, does anyone know what it could be??? im not sure at all what it is, the car rides fine, but it annoyes me i wanna know what it is....... thanks
Mike
1 of many things......
my first guesses would be
1) - fouled spark plug
2) - Faulty spark plug
3) - Wrong gap on spark plugs
4) - Spark plug wires hooked up incorrectly, sounds goofy but happens.
5) - Need to check dwell/timing
Start here...it's the basics
L8
L8
how do i know if the spark plug is fouled or faulty? and also how do i check the gap? i got the right spark plugs i know that the wires ARE hooked up right i double checked, the first time they werent and my car cut out when i put it in gear and i fixed that. and what u mean by dwell/timing???
L8
wires should be one
gaps should be two :)
Originally posted by FlipFlopBox+Nov 4 2003, 11:44 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (FlipFlopBox @ Nov 4 2003, 11:44 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--1 LO 64@Nov 4 2003, 06:20 PM
L8
how do i know if the spark plug is fouled or faulty? and also how do i check the gap? i got the right spark plugs i know that the wires ARE hooked up right i double checked, the first time they werent and my car cut out when i put it in gear and i fixed that. and what u mean by dwell/timing???[/b][/quote]
You need to find out if you have points setup......take it to a shop, they have equipment for you..Probably cost you $20
L8
what do you mean by points??? ill have the shop look at it tomorrow on my lunch break, i work at oil experts and auto experts is next door ill go talk to luther the manager and have him check it out for me.
Thanks
Mike
Thanks
Mike
if you're having these problems on the 82 caprice in your signature then points cannot be the problem because they stopped using those in 1973. GM went to HEI ignition in 74.
yeah i know its a hei well now i know a total of two things that ARENT the problem
1. points
2. wires hooked up wrong
put why could it be possible i have the wrong gaps if i have the correct spark plugs???
go to a autoparts store they will tell you the gap size for your ride, just buy the gap tool and redo the plugs, make sure your wires are tied away from the block.
i got a hei distributer cap (w/ coil) if that turns out to be the prob.. if not, duece is right, and a plug gapper would cost ya every bit of 2 bucks.. and to answer your question, (how could the gap be wrong if i bought the right plugs) the right plugs basically means its the right size and produces the right amount of fire for your car, but you have to gap every set you buy.. be easy man. good luck.
p.s. buy the distributer any way.. its bound to fuck up sooner or later.. who knows.. 15 er 20 years down the road.. you might just be lookin back sayin.. damn i wish i woulda bought that.. lol
Triple OG
yea, I would say it's the gap size too...go to autozone, they have gap tools for 99 cents.
where on the southside you at?
1. points
Your Gap is probably 35 or close to it. Regardless what it is.....let us know when you find out....
Just because you have HEI doesn't me they don't have problems.....I had one that missed constantly.....if thats the case
Check -
The cap for cracks..take the cap off and look inside on the gold terminals, if you're missfiring, one of them will be black.
Check the coil....you will need to ohm it out to make sure it's good.
L8
1 - 14 of 14 Posts
