Originally posted by Dvlshtndcy@Sep 20 2003, 09:25 AM
If #5 is the only one going out... I would say your looking at a scarred cylinder, bad rings, or a valve issue/head issue. Did they run a compression test on it? If it is within tolerance may just want to run it or you can tear into it to find the issue. A module control all the cylinders/engine to adjust fuel/air mixture as well as other things.
But, if your taking a car to a shop to be worked on, then you may be looking at a few bills to find and resolve the issue. Now, the rest of us backyard/weekend mechanics would just take the 3 hours to pull the head and find out what is going on. But, this still cost about $40 for new intake and head gaskets. While it is off you can have the head miced and valves checked at the machine shop usually for free.
