First off, I'm looking to juice my daily 86 regal. Just looking to get a few inches off the ground and possibly park it in 3 wheel. Not looking to do a full blown show car setup or even hop it against other cars, just using it as a toy basically.
I'm pretty set on getting a pro-hopper competition setup with 8" in front and 10" cylinders in rear. 2 pumps, 4 dumps, 10 switch box. I'm still undecided on 4 or 6 batteries. I'll be having the rear humps reinforced for sure, what else should i definately get reinforced? I've done a bunch of research and figure i'll use a coil over setup since it's a daily. I'm still undecided on getting accumulators though. Should i be replacing ball joints, tie rods, etc before having it juiced? Any suggestions, comments, info, etc is appreciated.
4 batts will get u a power 3 wheel i dont think a standing tho
My Regal runs 8"s up front and 10"s out back. I can power 3 wheel but not stand 3. As for what to reinforce, your front spring pockets and a-arm mounts would be good. Also the belly under the engine. It is also good to replace your ball joints and bushings as well. ;)
Okay, i'll be going with 6 batteries, 2 pumps, dumps, not sure on the accumulators yet(probably will since it'll be a daily car). I'll have the rear humps, a-arm mounts, and front spring pockets.
For what i'm looking to get, just for the pro-hopper set-up, how much should i be looking at spending just for parts?
