1 - 13 of 13 Posts
Whos know or has done it whats the highest u can lock your fleetwood up and did you just extend the uppers and shorten the driveshaft holla at me 16 and still can drive???
guy in my club is running 14 inch cylinders no prob and he drives it no chains yet
his drive shaft is off a 65 impala. whatch your front bumper when hopping it may hit.
I drive 14's in my 94 fleetwood...I have the stock drive-train, it hums all the way up, but it will drive.....(of course I usually tap it down)
shorten driveshaft ...extend upper trailing arms...
well i dnt know if this will help but i just put 14s and power balls on mine and i get a pretty high lock u. but in order for me to get that high lock up.they had to xtend my uppers trailing arms 1inch. it make a big differencein the high cuz i had 10s b4. but when i lock it up i can fill the drive shaft grinding. its cuz the drive shaft is being push into the tranny and also the u joint from the axle is binding. i plan to put a slip yoke on it soon. shud stop that shit. ill try to post pics of my set so you can see.
i did adjustable uppers and 5" dropmounts and i got like 4" of lift extra but the drive shaft does bind,def getting a slipyoke next.i have 14's and can stretch them alll the way out but i need more coil to take advantage of the extra suspension travel
1 - 13 of 13 Posts
