Here a few pics of the front factory air struts and a t bird strut I have laying around. They're sleeve style bags and I am uncertain of the max pressure they can hold safely. Right now my system is at 180 but I've seen up to 200. Lift in the front is still a bit slow to me that's why I wanted to go with a slam bag. Based on what the guy did in the previous pictures I might be able to cut off half the strut housing, slide metal tubing over the strut housing, and weld it inside the lower factory bag cup. From there I can weld a circular plate as a bottom mount for the bag and weld and upper cup to the upper factory strut mount. I could use either the air struts upper mount from the mark or a t bird upper mount. The t bird mount is shown in the picture with the coil spring.
