1 - 20 of 20 Posts
G
Hi,
my buddy got a 89 ford escort and it was running fine till yesterday(he got it last week)
After driving for an hour in hot weather, the car could barely make it up the hills. When he floors it, it doesnt shift down and car almost stalls.
then we park the car and let it cool for several hours. come back to it and it runs fine again..but after driving for a while, happens again.
The car has EFI.
any help is greatly appreciated.
thanks
shit could be nething, use a scanner to check for stored codes thatll help alot, i dont know much bout small ass ford motors
yeah, get some diagnostic codes from the computer before u do anything.
did it over heat or engine get hotter then normal....or fans not kicking on..if answer is yes to either of these...could be a blown head gasket....fords are know for that
Word, if those things get too hot they won't do nothin for you.
why are u wasting ur time with an 89 escort lol. a new head gasket is worth more than the car lol jj
it wont show trouble codes if the check engine light isnt on...
it will still show codes. When that check engine light comes on something has failed and or is totally damaged/disconnected.
CATALYLITIC CONVERTER stopping up , or FUEL PUMP losing pressure when hot
your buddy needs to stay away from 4 letter words.
you can take the radiator cap off and start the car with the cap off, let it warm up, and see if the antifreeze is flowing. a thermostat is good to replace every now and then, its cheap and fairly easy. also while you change that id flush the radiator.
the catalytic converter could be stopping up or something, the scanner wont see that and youll change everything, spend enough money triing to fix it that you could buy a g body and be happy. anyway if it gets stopped up or something, it wont let the engine breathe properly, and that wont let the engine run right.
my buddy was having a problem with his car, spent close to $1000 triing to fix it, changeing sensors, fuel pump ect., took it to the chevy dealer, they couldnt find anything out. it ended up being the TPS. take it to a shop and get it scanned first befre you start changeing parts.
Originally posted by nutsaq+Aug 7 2003, 10:30 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (nutsaq @ Aug 7 2003, 10:30 AM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--ImmortalTowncar@Aug 5 2003, 06:37 PM
I put my money on this here[/b][/quote]
If it's the cat, then just gut it out.
Or just give the car away to a charity for a tax benefit.
take the cat off and break all the honeycomb stuff out with a long srewdriver or a pipe. same thing happened to my moms broncoII and it drove me nuts tryin to fix it. finally figured it out and put a glasspack on it. :cool:
The Great White Hype
check the o2 sensors my bravada did the same thing and the shit would die if you pulling anything, the auto shop ran the codes and i replaced what they said and it still didnt fix it, A word from somebody that was in you shoes " Get A G-Body"
ok info for all, the easiest way to check for a stopped up cat is to have someone rev the engine and you listen to the exhaust tone if it just sounds like a blowing noise then the cat is more than likely stopped up if you hear a good tone and feel pulses of exhaust waves then the cat is ok
Triple OG
Originally posted by Foompla@Jul 30 2003, 03:06 PM
buy a chevy  :biggrin:
[snapback]932652[/snapback]​
when I seen this topic the only reason I opened it was because I knew someone was going to be an ass and say get a different car...
:roflmao: :roflmao: :roflmao:
I didn't expect it to be the second post...
coil could be getting warm and failing .. plug wires on verge of going bad ...
(TIMING BELT...egads man!!!!change them every 60kmiles or was it 30? )
[snapback]960033[/snapback]​
last i checked, glasspacks werent legal anymore, unless thats a state to state deal.
1 - 20 of 20 Posts
