1 - 17 of 17 Posts
ONE OF PISTONS IS NOT FIRING, AND NOW OUT OF NOWHERE MY ENGINE WONT TURN OVER. IT STARTED UP THIS MORNING BUT THIS AFTERNOON NOTHING! ANY SUGGESTIONS OR INFO WOULD BE APPRECIATED. THANKS HOMIE.
Originally posted by budgetblueoval@Feb 4 2010, 01:49 AM~16508307
what caddy and motor
I bet you its a 4100!
lol. if it is...., pull it out and put a 350. it will save you time and money.
i cant tell what your prob is just from what youve told us. but i would look at the crank. it might have cracked causing one of the pistons not to turn. or when was the last time you drove the car. if it sat for a long time. the pistons might be rusted to the block. or the motor dont have enuff lube to keep everything loose and moving right. so the inside of your motor might be sticking together. gunky oil will do the same thing.
i had this prob on a car that i pulled out of the bushes in a old ladys back yard. put just alil bit of oil down where the spark plug holes are. put alil bit in each piston to lube up the piston ring. i used lucas. (i tried WD-40. but it didnt work for me. thats why i used oil. you can try WD-40 and see what happens. but id use lucas) crank the motor over and it should start spinning faster.... then it should try to start. it will smoke until it burns the oil off of the piston, but it should run and lube the inside at the same time.
hope this helps. :cool:
i dont feel tardy
and id bet you
your a fucking idiot that barely knows how to turn a wrench
what do ya wanna bet?
Originally posted by REV. chuck@Feb 6 2010, 05:46 PM~16534048
and id bet you
:0
and id bet you
A homie im a hvac service tech for over 13 years I can turn a fucking wrench you fucking hater!
IS XERXES THE GOD-KING
topik givs me lulz
-394 CUSTOMS-
Originally posted by REV. chuck+Feb 6 2010, 05:46 PM~16534048-->
and id bet you
[/b]
<!--QuoteBegin-CaddyKid253
@Feb 6 2010, 06:50 PM~16534525
:0
that applies to you too. a broken crank? come on bitch.
it could happen. i didnt see YOU give any advice, bitch.
LMFAO, I FUCKING LOVE THIS TOPIC
he called chuck a 'hater' :roflmao: :roflmao: :roflmao: :roflmao: :roflmao: :roflmao: :roflmao:
watch out chuck, fool mite want to meet you by the monkey bars
1 - 17 of 17 Posts
