IF A CAR HAS FACTORY AIR RIDE CAN IT BE MADE TO HAVE SWITCHES INSIDE THE CAR TO FILL AND DUMP THE AIR???
YES! It can, because it is most likely solenoid controlled. HOWEVER, Dump speed will be slowed by the small lines factory air uses. And lift speed will be slow because it will becoming direct from the small onboard compressor. YET, it is still fun as hell. ESPECIALLY considering it is free!
Yes an aftermarket compressor, as well as larger lines could be installed. BUT depending on the bag and how it is done, you may or may not be able to increase the opening size in the actual bag. Which would eliminate thew point of larger lines. (ie. 1/2lines with a 3/16s opening will eliminate the larger lines purpose)
HOWEVER, with a compressor that flows more CFM then a stock one (which any aftermarket surely will) will speed up lift times. But in no way expect these results to be fast.
EDIT: btw, wondering what car you are working on?
