1 - 8 of 8 Posts
G
Hey whats up, i've been on this board for a while just reading and learning, i got a '99 olds alero juiced but it's just no quick enough for me, i have a CCE 2 pump street setup runnin at 36 volts #8 hoses, accums, it's not quick at all, I have a few questions. If I got comp pumps would that be all I needed to be able to get up at the hit of a switch? i'm not wanting to hop, i just want to be up as soon as I hit the switch. I'm also getting 4 new group 31 batts so i'll be runnin 48 volts. And do you guys know if there is a difference in the reverse flow cylinders made by CCE/ProHopper/Showtime? they look different..i'm just curious, thanks much guys!
The reverse flows are all pretty much the same, just cosmetically different. You really don't have to be concerned about who makes the best b/c your not really gonna be putting a sh*t load of pressure on them to blow them.
All you really have to do is upgrade your pumpheads. You probably don't have a good pumphead in those pumps. Just one that'll do the moves.
Buy some Marzocchi pumpheads & put them in the pumps you have now. I'd go w/ a #11. Yes the #13 is faster, but it may be a little faster than what you want.
1980 Cadillac Fleetwood 90’d out
If you dont mind miss matching parts. I think prohopper has a better track record as far as reliability goes. So, the reverse flows from Pro Hopper. CCE makes a real neat coil over kit with a swivel top cup. I would use that with the P.H. cylinders
1 - 8 of 8 Posts
