1 - 9 of 9 Posts
i have a 267 in one of my cars right now, the motor is in desperate need of a rebuild/swap, so im figuring that i should just get something bigger (if the price is right)
so, my question is, what would be needed to convert a (tbi?) 350 to carb, granted that i have parts from another sbc at my disposal..
same question, but applying to a 305.. what would i need, or could i swap parts from my current sbc to convert the engine to carb........
thanks..
eazy
thanks..
eazy
Going FROM FI to carb is easy, especially a TBI. Just swap intake mainfolds and put a carb on for the air/fuel. You may have to get an intake that has the inner 4 intake bolt holes slotted so that it can bolt to the FI style heads. This is easy though, you can even drill out a carbed one if you wanted.
As far as spark is considered, swap out the electronic advance distributor for an older 76-82 style HEI vacuum advance distributor. Then you can just hook up the vacuum to control the advance of the spark and totally eliminate any need for a computer. Nothing else I can think of off hand......
that sounds easy enough..... thanks... ill be asking more questions as soon as i get started...
you need to get a mechanical fuel pump
thats what im wondering, can i take the stuff off of a (267) sbc????
im thinking, they're all small blocks, most of the stuff should fit...(intake?, fuel pump....)
to clear it up a little more, the car was an original carb car, so im not converting everything, just the replacement engine...
yeah i forgot about that
and don't forget the pump pushrod
can i use the pump from the old sbc???
Originally posted by pink63impala@Sep 23 2005, 10:24 PM~3875174
geta new one. theyre like 9.99$,youll need some fuel line too :biggrin:
oh, i know that, just checking if there were diff sizes for each small block.....
didnt really matter, im not in a rush, just wondering
1 - 9 of 9 Posts
