1 - 2 of 2 Posts
Whats the proper steps for prepping a fiberglass header for paint (ie 80's cutlass header). Its got no cracks, but lots of rock chips. Should I just sand it down, fill feather and highbuild.
well you got the prep steps right,,,try a thin layer of evercoat if you have fiberglass resin,,you can thin that evercoat pretty thin,and lay it with a spreader,then block it out,you can also block it all out without filler,but then you will minimize the strenght on the header,,,good luck man!
1 - 2 of 2 Posts
