1 - 10 of 10 Posts
My windows stoped working the other day and after an hour of going threw every piece it could be i found it to be my window relay
The only proublem is i cant find anywere to buy a new one. Does anyone have any places i could look befor i start running around to all the junk yards.
The other thing i was thinking is would i be able to just wire in another relay ? And if so how would i find one to meet the same power ratings to i dont end up frying something
Its a 1969 cadillac coupe deville
Alex
Alex
yeah just get one thats about the same(as in same design and rated for same amps with same amount of prongs-just use female wire ends that slip over prongs if factory harness doesnt work-you can also direct wire your window motor...you just cant keep on the button when window is all the way up or down :cool:
How would i dind out what amp rating i would need? i sont see any markings to indicate anything ike that on the one thats fryed
hmmm thats no good-post pic ;)
ill have to get my camara from my friend but im looking at it now and theres a few things. Three prongs
One prong has an A next to it the other is B and the last one looks like P or F and then it has HI-RAM in the middle of it
well i found one on ebay but its 50 bucks for a used one and i just think thats too much
If i hhave to get it i will but i was hopeing i could just but in a new relay even if i have to wire in a new harness.
Also another question . Im puting in my weather striping and door panels so ive been rolling my windows up and down just by using a wire in place of were the relay was. Is that going to cause any damage to anything . Possibly my switches?
Hi there i just picked up a 1969 deville and the power windows are stuck down any idea on where i would find the relay
Moderator
Those relays in them cars are really old style relays. I had a 70 deville and noticed the horn relay/ interior buzzer relay was huge compared to new relays. Upgrade and use new relays. You can get the 30/40amp black box relays used for car alarms/stereos/fans etc at parts stores or stereo shops for about $5. Only good thing about the old ones are you can take them apart and clean them if that's all they need.
Hey there do you have any idea what the out put amps need to be i found a new relay and it now clicks but the window will not go down or up if i insert the old relay and hold the point down it works so i must nit be getting enough juice . thanks
1 - 10 of 10 Posts
