need pics how to wire spark plug wire to the distubutor where do they go
that would be right if the distributor was never pulled out b4,get #1 piston up first to determine exactly where to put the #1 plug wire.if u just put #1 anywhere the timing will be off.Originally posted by nwa_fo_lyfe@Aug 11 2005, 03:58 AM~3589638
1 8 4 3 6 5 7 2 -- one is the farthest back and to the right
and a olds 350 and pontiac 350. Well, actually also olds 307s, pontiac 301s, pontiac 400s, olds 403s, chevy 400s etc etc I could go on but you get the hint :biggrin: oh and olds and pontiac turn COUNTER clockwise and chevy turns CLOCKWISE. Just FYI for the posterOriginally posted by nwa_fo_lyfe+Aug 11 2005, 03:58 AM~3589638-->If you are talking on the distributor, then nope on a chevy its usually located 2 wires counter clockwise from the center power plug in where your batt and tach wires are. Then, they go clockwise from there on. BUT like james said, go to TDC and find where the rotor is sitting to be certain.1 8 4 3 6 5 7 2 -- one is the farthest back and to the right
[/b]
Hopefully you weren't saying the #1 cylinder is farthest back and to the right...that would be 7 if you are facing the engine from the front.
<!--QuoteBegin-216RIDER@Aug 11 2005, 05:26 AM~3591348
thats correct, assuming its a chevy 350
fuck some BOP shit all to hellOriginally posted by Joe5pt0@Aug 12 2005, 12:35 AM~3598151
