1 - 20 of 56 Posts
As the title says, my friend and I fired up his (soon to be mine) chevelle today. it's a 5.0L 307. He hasn't started it up in a while, i'd say about a month or a little less. Anyways, we got it going because i wanted to tune it up a bit and just a get a feel for the car i'm soon going to buy.
Just did some basic stuff like sea foamed the engine, changed oil, check fluid levels, replaced fuel filter, cleaned air filter, fuel treatment...
What we noticed is that there is a good amount of moisture coming out of the exhaust. Like i could put my hand there and he'd rev the engine and my hand would be wet. The engine wasn't smoking or anything, so i figured that it wasn't a shot seal or gasket. I just want to know is this from the car sitting for a while? how detrimental is it to the engine and what can i do to get rid of it?
thanks a lot guys for any feedback.
Originally posted by mustangsalli@Nov 23 2008, 08:11 AM~12234496
Pay a mechanic to do a "compression check" on the engine if you want to get the best idea concerning the wear on the engine......!!!!!!!!
MS
:wave:
Married to the Ave
:uh: thats common for a car thats been sitting...moisture collects in the mufflers/pipes...drive it around for awhile its...probably fine...but im sure you will be pulling the engine out anyway and tossing it for something more appropriate for a 68 right? :happysad:
Condensation in the mufflers burning off. The car has not ran in a while so the moisture that collected in the mufflers is burning off and out the tailpipe.
Your damn right. haha. going with a 350 once i get the money to do so. :biggrin:
thanks for the replies everyone.
Originally posted by Lil_Peezy420@Nov 23 2008, 10:01 AM~12235255
350? go big block :biggrin:  :biggrin:  :biggrin:  :biggrin:  :biggrin:
haha i dont think ill be able to afford that shit, as much as i'd like to. i'd probably end up having to switch out the trans and modify the engine bay right???
409
A big block will drop right in to that engine bay
most cars put out moisture on start up its normal
Discussion Starter · #19 ·
Just the other day we filled the power steering pump with fluid. Figuring it would fix the power steering problem. It didn't. We turned the engine back on and it began to spray the fluid everywhere. He just got the hoses replaced but the pump and everything else is all original. Anybody have any ideas on this one? Do I just need a new pump?
Did you OVERFILL the power steering pump with fluid beyon the markings or not have the hoses threaded in all the way???
One hose handles the pressure and the other is a return line.
Only other places to leak from are the pumps seal at the bottom or the power steering cylinder/actuator gaskets themselves-
MUSTANG SALLI
1 - 20 of 56 Posts
