1 - 8 of 8 Posts
some people may have come across the problem of headlights hazing up w/ a yellow haze.
this is a trick i recently learned to fix em.
1. wet sand headlight w/ 1000 grit sand paper until light looks clear.
2. follow by sanding headlight again w/ 1500 grit sand paper to get out the scratches the 1000 grit made.
3. finish up by buffing headlight w/ rubbing compound and then a glazing polish.
before:
after:
Originally posted by drug_lord@Sep 4 2005, 08:45 PM~3754017
nice but what if the inside gets hazy?
i always thought it was the inside when i saw lights like these. i looks like its all on the inside. its prob not.
try it. it cant hurt. ;)
if its by the inside,Pull the headlight and put it in the oven for a bit,take it out and pry off the lense from the housing,then polish from the inside and put the lense back on with silicone :biggrin:
what if u do not have a wetsander....
i used my hand :uh:
1 - 8 of 8 Posts
