1 - 3 of 3 Posts
I got 2 subs for sale. Nothing wrong with them just upgrading. I run 1650 to each and they sound great. Looking to get 150 each plus shipping.
FLAME Q SERIES
VERSATILITY
In ported enclosures, this series of subwoofers produces a flatter response over a wider range of frequencies. In sealed applications, this subwoofer takes great advantage of the flared voice coil former’s heat dissipation.
FLARED VOICE COIL FORMER
Since heat deteriorates every electrical component, Audiobahn has designed this series of subwoofers to better dissipate heat through the cone. This is accomplished by a unique flared voice coil former which attaches directly to the cone with a large contact surface. Heat travels through the flared former to the aluminum cone. The cone has a large surface area for dissipating heat, much like the heat sink of an amplifier. The result is a subwoofer that runs cooler, more efficiently and handles more power.
CAST ALUMINUM BASKET
All Audiobahn Cast Basket Subwoofers are made from high-strength, chrome-plated aluminum. Measuring in at 6mm in thickness, the heavyweight design is fundamental in the subwoofer’s overall performance. Having a thicker-gauged cast basket is important because, in high-power situations, smaller, thinner components may vibrate and cause unwanted mechanical noise.
COMMON FEATURES
PHAT 2” Multi-layer Foam Surround
Stamped and Balanced Aluminum Cone
Dual 4 Ohm Voice Coil
2 Ohm or 8 Ohm Operation
6 mm Cast Aluminum Basket
Multi-connect Lug Lock Terminals
Post in the CLASSIFIED SECTION...that will help. ;)
1 - 3 of 3 Posts
