1 - 20 of 24 Posts
hey guys the topic says it al :cool:
i have a fucking promblem with my 93 it starts runs nice for 5,10,15, mins the dies and wont restart for a X amount of time
never the same
the pump the relay for the pump was
changed
im thinking of doing a tbi to carb conv.
did some one all-ready do it
or is there a
How To on the forum
thx
:cheesy: :cool:
409
Originally posted by CoupeDevilleDTS@Dec 6 2008, 09:49 AM~12352929
dont think no one has done it because its alot cheaper to fix your car the right way and its better to have fuel injection than a carb in the long run with fuel mpg and performance
x2
did you chek your fuel pressure, when it turns off, try craking it and have some one look at the throttle for gas,if no gas its gonna be your pump. get a big ass 2x4 and hit the tank while cranking the car,check your spark, it can be a bad module, had a similar problem with them 92 roadmaster, it was the module, keep it tbi, it works better than pumping the gas petal 20 times to start on a carburator :cool:
what module?!
hehe
thx for the info
for sure i want to fix the engine
i want my int done before the chromed out 350
hehe
misspelling carburetor= you fail
i dont think its ur fuel pump
its the module, coil, or distributor
check if there is spark after the car turns off
Discussion Starter · #15 ·
yeah ill check that after changing the filters
what module you guys talking about?
u and a car are canadian but the american module looks like this
and it goes inside this
check your fuel pressure regulator homie.
have you done a tune up?
if not i would also do this. the parts are very cheap.
spark plugs $20
ignition wires $30
ignition coil $25
distributor cap $15
distributor rotor $10
ignition module $50
go to advanceautoparts.com or autozone.com real simple to work on these engines homie goodluck :thumbsup:
1 - 20 of 24 Posts
