1 - 9 of 9 Posts
I like the atomization of a 1.3 for fine pearls & Kandy's... a 1.4 is all around good ... & you can use a 1.5 for clear ......... 1.7 or larger for primers......
Fuck the paint I use a 1.3 is all you want to use for base and clear. I use a 2.0 for primer and depending on what I am spraying for a primer I just adjust the fluid flow and pattern to conpensate! Its hard enough getting polysurfacer to flow out of a 2.0 anyways and lay down nice and even.
yeh i got 2.2 in my primer gun for polyester primers..
and been using accuspray "isaac" with
air cap 706
fluid cap 36
what size is that in metric??
Originally posted by Illustrious Auto Works@Dec 8 2003, 10:50 AM
I've been using a Sata Jet 90 for about 6 years with a 1.4 in it for base, candy, and clear. It works perfectly with all of them, just adjust the fluid control. I also use a 2.0 for high build primers.
i have had the use of a sata 90..
good gun.
one thing i forgot to mention my accuspray is an HVLP gun.
i find these much nicer to work with once u get the hang of em.
should be a lot more economical to use when spraying that expensive paint..
1 - 9 of 9 Posts
