1 - 17 of 17 Posts
A
Guest
Hey there,
Just finished my single pump hydraulic setup today. When i activate the lift, the pump kicks in and the solenoids open and pressurises the system which raises the car as its supposed to. But, if i activate dump to lower the car, the dump solenoid kicks in, but the car doesnt go down at all.
Any ideas are appreciated.
A
Guest
we have tried everything with the valve and no joy :(
I love hearing "PAPA"
Originally posted by AustinPXX@Nov 24 2003, 02:38 PM
Hey there,
what voltage is the valve? 28VDC will not work with 12VDC.
Do you hear a click of feel a thump when dumping? is the valve grounded -correctly?
A
Guest
Its a 12v valve running off a 12v system.
I cant feel anything happening, but i took it all out to check it and its definatly kicking in :s
A
Guest
UPDATE:
We have looked closely at the coil setup to see that it is dumping VERY VERY slowly, we are talking the springs umcompressing about 1mm every few seconds. The slow valve makes no difference to this, is there a chance the dump valve could be sticking or isnt opening all the way?
Maybe the valve is sticking. what kind is it? If it looks like an Adel/Adex clone, who made it?
A
Guest
I have no idea on a make. I live in the united kindgom and its an OG kit supplied by Rayvern Hyrdraulics, being as it is 12am here we cant contact him, but frustrating when we have just finished the system :(
How many ports, are your fittings in good shape and are there clear makings on the valve that state pressure and return, or something like that and have you hooked it up that way?
Is the return hose in good shape, this all meaning, can you blow throught all the valves, fittings and hoses? (n the return side?)
Activate the valve and see if you can blow through it first,
maybe try 24 VDC for a few tries.
A
Guest
Everything seems set up correctly. When we activate the dump valve you can blow through it but it is EXTREMLY difficult.
Seems to me a oring blew. I say take it apart (unless is under warranty) see what' looks different.
Be careful of springs that fly out, hmm... maybe something got bent.
single pump...................so you have a dump on the pump and a row of two or four lock valves as the standard "ray" setup?
check you do have 12v coils.
if you have the setup as i asked above, you need the dump and a lock valve open to drop, not just the dump.
you will be able to feel/hear the valves open/close when you operate the switch.
use a test meter to check volts to the individual valve coils.
check your earths.
A
Guest
Discussion Starter #15
When i activate the dump it opens 2 locks and the dump.
Its all wired correctly and all connections are brill
O-ring blew, meaning I wonder if a piece of it has got caught on something, and does not allow easy of movement, not that the o-ring came off.
If it has two orings, then maybe the first has a piece broken off and got caught and the second is holding the pressure
does it have a slow down valve?
so you know the lock valves can operate from when you lift...........have you checked [electrically] that the operate when you dump.
you dont say if its front/back or not? does any of it drop............
does it drop if you crack a hose to let the oil out? [betwen the locks and cyls]....if not there is something binding with your install or not enough weight]
1 - 17 of 17 Posts
