1 - 20 of 24 Posts
hi guys what fluid do you use? reason is im useing a hydraulic fluid.but i was just looking through the tech section on the pro hopper site and it sez to use motor oil.is this right.???????? :0 :0
[snapback]3540498[/snapback]​
Motor oil is all I use. It's also recommended by Pro Hopper and Showtime. Hydraulic fluid works fine as well but is more pricey. And in desperate times when I was stuck in the middle of nowhere I used power steering fluid. Worked just fine.
when they say motor oil they mean sae 30nd ... you want to use non detergent cause that detergent stuff will eat up seals ...
i also get mine at the dollar general / family dollar stores a dollar a quart.. and its the same stuff the gas station sells for 2.89 a quart...
I was told to use hydro oil AW32 but my pumps work much slower and would not extend all the way, I switched back to motor oil 10w30 gtx and every thing is fine. why must it be non detergent oil? If I change the oil every 2-3 months by flushing it with new oil what would be wrong? Also does any body run inline filters?
r and o - aw 32 is much better
r&o hyd. fluid....... autozone 5 gal.$18 nd30 is a little thin for me but dosent thicken up like the r&o when it's cold....
if you pay a thousand or so dollars on a setup, whats 25 dollars for 5 gallons of good hydraulic oil?
Originally posted by schmidt64@Aug 8 2005, 12:46 AM~3559504
you all can afford $2000 hydro setups but cheap out on $20 worth of the proper oil?
I plumbed my setup this time at like 4 am, grabbed some 30 wt oil from the gas station. :dunno: works fine, and I guess prohopper reccomends it, so I don't see what the big deal is. I'm not in a hurry to change it out, I could care less as long as it works. I realise that's what hydraulic oil is meant for, but I don't get why people are so uptight about it, I've seen it in like a dozen signatures on here.
Originally posted by 81delta@Aug 6 2005, 12:09 AM~3550952
Shit. I thought Hydraulics...Hydraulic OIL...
I'm gonna give regular engine oil a shot. Save a few bucks :cool:
not just regular oil,make sure it says Non-Detergent, most stuff you see for cars is detergent.
but walmart did have big 5 gallon buckets for like 15 bucks (for tractors and crap if you go lookin for it)
1 - 20 of 24 Posts
