if your talking about some mad inches then yes indeed you can.
first off you would need a good 575 cft. or more of helium/nitrogen bottle w/a regulator at 400 or more psi
4 5 gallon tanks (faster fill time)
slam or conitech (4ply only) bags
1/2" or higher valves/lines/fittings etc.
and you should be flying in no time.
[snapback]3457172[/snapback]​
you didnt just say that slams where 4ply did you?
Originally posted by VGP@Jul 23 2005, 12:19 AM
bags only?  If you can do it with bags, then you should definitly be able to do it with cylinders as well, right?
[snapback]3462302[/snapback]​
why definittly? must be a newbe.
cylinders for air will bend, they dont hold great pressure ither..the ones make for cars
Originally posted by aleigh-n@Jul 23 2005, 01:41 AM
no only the Conitechs
[snapback]3462720[/snapback]​
:biggrin: K, i was just checking. i was looking to chew on someone
