1 - 16 of 16 Posts
Can you tell by eyeballin it or do you have to run the #s? What's the good and bad for each? I'm sure I'll get some chevy fans on here telling me to buy a chevy -- got one of those too!!
Cleveland 351s had 8 valve cover bolts, WIndsors had 6, Clevelands did not have water outlets on the intake manifold, while Windsors did..
don't quote me on this, it's what I've observed, a couple Ford friends confirmed it to be true, but I'm not 100%
From what I've seen, Clevelands were good, but now Windsors are better hands down...
I ALWAYS THOUGHT CLEVELANDS WERE BETTER BUT I DON'T HAVE ANY FRIENDS INTO FORD'S... :biggrin: SO I'D SAY UR RIGHT...
OHH YEEEAH!!!!
On a windsor, the thermostat housing bolts to the intake & turns up to a 90* angle(like a 302 or 289).
However on the cleveland the thermostat housing attaches to the block & points straight up. That motor doesn't have coolant running through the intake.
Don't confuse the Cleveland with the 351/400 "modified" motors. They look the same except on the M engines There is a "m" or a "2" stamped one of the top corners of the heads near the valve covers.
Also the front of the block to the right of the distributor it has an elevated ridge(1/2"), where as the cleveland doesn't, its just flat.
I think the Boss-302 engines are essentially a destroked 351C, but chances are yur not going to find one of those.
Also, Fords suck it big ;) .
Originally posted by 64SS@Oct 12 2007, 05:34 PM~8988598
How to tell a windsor from a cleveland?
The Cleveland has an Indian on it and there is nothing for the Windsor.
The Windsor is like a "large" 289/302 where the Cleveland is more like a "small" Big Block Chevy in layout.
What you should do is get a chevy!!!!!!!!!!! :biggrin: :biggrin:
:thumbsdown: bandwagon
Originally posted by 67juiced@May 20 2008, 01:55 PM~10697118
What you should do is get a MOPAR!!!!!!!!!!! :biggrin:  :biggrin:
FIXED... :biggrin: 440'S ARE GREAT MOTORS....
Discussion Starter #15
Let's run 'em (to the gas station!!!!) :biggrin:
1 - 16 of 16 Posts
