1 - 20 of 247 Posts
:cheesy:
all plates is lasercut...
no heat was used to bend any of the plates.
crossmember done 3 sides,
still molding to be done along with plating the bottom side:
inside of the springtower getting dressed before the top crossmember plate is welded in place:
left front rail getting wrapped and molded:
just ONE plate goes from the rear trailing arm mount and to the front shocktower, brackets were cut of before plating...
another:
tranny mount rewelded and molded after plating.
Discussion Starter · #13 ·
right frontrail inside before molding:
front a-arm mount rewelded after plating...
another:
note how the sides gets double wraped and the top is hole drilled and plugwelded to keep the frame from twisting.
Discussion Starter · #17 ·
the X double wrapped and molded:
1 - 20 of 247 Posts
