1 - 15 of 15 Posts
what do i do? will i have to take out the lower a-arm to release the pressure? also, the worst thing is that as it got towed to my house, i drove it in as i could still drive it and the brakes completely failed, and i crashed it into the end of my garage.
is it normal for the brakes to fail if the cylinder isn't sitting right or am i dealing with two completely separate problems?
yeah that sounds like it, but i'm pretty sure i checked the brake line and it looked ok, better check tomorrow in the daylight. thats the only thing that could do it right?
ya u gotta break the ball joint to get the pressure off the a arms
x2......
if u have a torch cut the coil in pieces were it is so then u can just unbolt like normal..
Originally posted by Lee337@Oct 6 2007, 05:48 PM~8944705
wtf
is this a common problem?
never heard of a coil shattering before
Does the spring look pitted and rusting away? I had one break on a Regal a right rear spring because the car was from Ohio and the weather caused the spring to corrode and lost its ability to flex, they turn brittle and eventually break.
well i got it out. had to do a bit of a macguyver with a bit of wood and old jack but its out. the springs were only a year old. i bought em off a guy who does a lot of hydraulic installations. i have heard of this happening when the springs are cut with an oxy or somethin but yeah, weird. now i guess i'm gonna change all four.
IVE NEVER BROKE A COIL, HYDRAULICS OR NOT!
The Great White Hype
You must not be pushin it to the limit :0 :0
:biggrin: I broke some in my bed :biggrin: :biggrin: :biggrin: :biggrin: :biggrin:
u can cut them with torch..i dont but the key is letting it cool on its on if u put water on a hot coil u have ruined it...i bought like 3 sets of hilow jammers coils during there breakdown and every set broke snapped the metal was really shitty ...i hope they have got things together...
Discussion Starter #13
yeah well in australia the lowered springs you buy aren't low enough, so you pretty much have to cut em if you want a low ride. ima just hit some more 2-ton coils up, use a grinder.
invest in a band saw , it will save you time :biggrin:
YOUR RIGHT, BEST I EVER DID WAS 40" AND THEM 4.5TONS TAKE IT LIKE A CHAMP
1 - 15 of 15 Posts
