1 - 5 of 5 Posts
Need help..im new to this but i got a 98 blazer with a 2 pump 4 Battery set up.i hit my front switch and nothing but a click.all my other switches work fine.so changed the noid and it started lift a bit but slow and now just clicking again and no lift..i just changed 3 of 4 battery and still same.my next guess is pump.could it b anything else..
I got the wildstyle
Instragram: Kiloz_One
Check valve would probably be the next thing to look at. Is it both pumps that arent working or only the one? try swiching check valves and see if that fixes it, there are tons of good check valves on the market.
Load test your batteries, It sounds like you have a bad battery.
1 - 5 of 5 Posts
