1 - 11 of 11 Posts
WAS RIDING AROUND TOWN..HITTIN SWITCHES..EVERYTHING WAS COOL...THEN...
I go to lift the front end and it only lifts halfway then stops and i can hear the oil being WIPPED..LIKE IT IS JUST GOING AROUND AND AROUND...
is it a blown o ring where the pumphead meets the block pressure port...or is it my dumpvalves ?
looked in the tank and the oil is all FOAMY
update ::::: it was the PRESSURE SEAL..IT WORKS FINE NOW !!!
I closed my slowdown valve all the way..nothing changed..
I think I blew the o ring that goes on the block
motor spins just fine and the pump head works..just aint throwing enough pressure to the cylinders
and my oil in the taNK IS ALL FOAMY
Originally posted by Cadillac Bob@Oct 27 2003, 07:55 PM
Yep, sounds like a popped pressure seal. Make sure you get the pumphead nice and snug onto the block after ya change it, use a torque wrench and put at least 25 lbs on em.
YEAH.. I guess I gonna have to replace the seal.. sounds like a blown pressure seal to me also..
dang..that means I got some work to do.. !!
now before I go through the trouble of breakin my pump down..does anyone else got any ideas as to what the problem is..?
1 - 11 of 11 Posts
