1 - 3 of 3 Posts
the gauge shoots to full when the car is turned on and stays on full it only comes to empty when the car is off...i took it to 2 different shops and they told me it wasn't the float in the tank that they did they lil test with the wires and said it was the gauge...so when i take the gauge out it moves freely i get another from a user on here and it does the same thing...it cant be both gauges are bad or i hope..can any one shed some light on this and maybe guide me in the right direction... im not sure what to do with this...unless its a ground..
i had the same problem in my buick and had the same test done and swaped out 3 guages finally just replaced the float and it worked fine
hey try changing the fuel pump and sending unit or check the floater good luck carnal :biggrin:
1 - 3 of 3 Posts
