1 - 20 of 24 Posts
whats up yall!! need help witth trying to fit 16x7's Player wires in the skirts of a 93 Fleetwood. The rubber rubs the skirt, I'v tried 205/55/16 and 195/50/16, would a narrower and taller tire work or can I bulge out the skirts 1/4". I'v also ground down as much as I can off the inside of the skirts. Anyone have had this problem befor or any ideas
car and wheels are fwd ..........if you mean shortening the axl it seems like a lot of work........never done that before got any pics?..... is a customer's car but i'll try .....does'nt sound to hard
thanx
i have a sedan d ville 94'
fwd car
fwd spokes
17" 100 spoke knock offs with 235/55/17 vogue
no cut no rub
i have pics if you want
thanx 4 the pics looks sick, I like the vogues. This year (93) has removable shirts, the handle that unlocks the skirt is what 's rubbing the rubber. Do you think shortening the axl is an option.
of course it is an option
but timely and pricy
remove the fender skirts try to manipulate or fabricate a new handle that won't hit
do you have a pic of your car
also are you using a fwd spoke or standard offset
my guess
mine are og fwd 17x8
in theory one would think a 16x7 fwd will be easier to fit
but since yours are 16 " they are not tall enough so the tire hits the handle
i think a 17 or 18 inch wheel would raise the tire higher in the wheel well so that the tire being higher will not hit handle on the inside of skirt
you should be able to cut the length on the handle that removes skirt in half and then fabricate a new fastener to attach the handle to
otherwise get some 18x8 fwd for about $650 and some new vogue 235/50/18 for about $750
good luck
UNLESS THEY ARE 'REAL' DAYTONS...THEY WILL RUB...THERE IS A LITTLE TRICK YOU CAN DO...TAKE OFF THE SKIRT....TAKE OFF THE CENTER ARM AND BRACKET...BEND THE HOOKS OUT ALITTLE...POP 2 OF THE PLASTIC CLIPS OFF (THAT HOLD THE RUBBER ON)..AND USE 2 SHEETMETAL SCREWS TO HOLD THE SKIRTS ON
ITS GONNA WORK FOR ME IF I DONT SCOOP UP SOME DAYTONS IT IS A POSSIBLITY THAT IT CAN WORK ON THE SKIRTS OF THE CADDY
IT WORK ON OLDeR CHEVS LIKE MINE ! :cool: :cool:
1 - 20 of 24 Posts
