I got a loud squeek I think it's the power steerin pump n the belts are touchin how do I fix this
x2, and if the belts are actually touching the power steering box that's mounted on the frame as if the engine is sitting lower, then check the engine mounts and frame for damage.Originally posted by maniak2005@Jan 21 2009, 07:41 PM~12775415
make sure there tight. and if 2 belts are touching on the sides then something is out of alignment
yea my old caddy had that same problem so i took some fine grit snad paper to the pully and it cleared it uOriginally posted by budgetblueoval@Jan 22 2009, 12:57 AM~12778871
it may also be glazed over and time replace
