I bought this 86 cutlass from a guy who was took the Olds 307 out and dropped in a Chevy 350 but didn't finish, I pulled it out to put a Olds 350 back in. This is were I need help . Can someone tell me which frame holes the Olds motor mounts bolt back to,I'm using a short tail tranny, or give me a link to get the info? Thanks in advance.
were the red lines go to is were the mount will bolt to
the bolt hole on the lower part of the mount that is closest to the front will hang over the frame so dont worrie also on the mount make sure you put them right side up the top holes on the mount should be spaced apart farther then the bottom holes
Originally posted by hosscutlass@Feb 8 2008, 01:14 AM~9893272 were the red lines go to is were the mount will bolt to
:thumbsup: I went and got those mount brackets off the car my motor came from, since they don't sell them new and I only had one. That pic is right, I got it now. Right On Fellas!
Hey guys I’m having same problem bought a. 86 cutlass no mounts putting a 307 back in no idea where mounts go , any help
Related Threads
LayItLow.com Lowrider Forums
17.7M posts
191.1K members
Since 2002
