look i guess ill tell ya since no one else has
step one ------- pull the moter and tranny
step two -------support the frame on jack stands as high as the jack stands will go
step three-------unbolt the old frame then jack the body up off the frame till you are able to slide the frame out some peeps in the getto use center blocks but i stress keep kids away
step four--------- transfer any and all need suspention componets to the new frame
step five------slide new frame back under the body and lower and line up bolts then
step six----- bolt the wheels back on then
put the moter back in
note------it might be easyier to remove the whole front clip and moter and tranny more work yes but thats what i would do
Originally posted by juicedinsanta12@Jan 17 2004, 03:56 PM
thanxs "78&64dropped", im actually gunna make real easy by taking it to get the motor and tranny taken out, im gunna do the rest. :cool:
your in there then are you going to rebuild it after its out
