1 - 13 of 13 Posts
i have 18 in strokes on my regal, after awhile of hittin the switches and three wheelin the bars came off and my trunk wont stay open, any one know how to change to gas shocks or know how to fix this problem
Originally posted by GM ONLY@Feb 6 2010, 09:18 AM~16531167
Did the bars break or just fall off track?
were they go on the sides they broke off so i got mad torch them out, i rather have the shocks in the rear
Originally posted by GM ONLY@Feb 6 2010, 01:38 PM~16532858
Sorry can't help then, they're pretty easy to get back on track but sounds like its too late for that. Good Luck
thanks bro
Originally posted by 350_85_BroughamCut@Feb 7 2010, 10:00 PM~16545197
Hey homie, they sell this kit on Gbodyparts.com, I'm sure this will solve your problems....I'll warn you, they are pretty pricey, but I'm sure if your good at fab'n up parts, you can study the pics and get a idea on how to make your own work
http://www.gbodyparts.com/product_info.php...c079236e12bf3cf
cool thanks hommie
The Great White Hype
their is a bracket thats on the 80's caddies that looks about the same...... just drill the rivits to remove and then whem you install it on your cauuty..... just use bolts :cool:
i added some gas shocks for the trunk lid cause i had to remove the tortion springs for cyl and speaker clearances,i think it worked out pretty
well.used factory regal hood shocks along with the factory bracket off the hood
That is the way to go. Only like $55 for new shocks at the parts store. Much cheaper fix. Then just fab up something to either bolt or weld them to.
i paid 8$ each shock off ebay and had a set of brackets that worked so i didnt need to make any....i was under 20 bucks :biggrin: ......what did the bird say when it flew over my garage.......cheap cheap cheap! :uh:
1 - 13 of 13 Posts
