can i upgrade to a 350THM easily withou any computer issues or should i just have the stock one rebuilt?
yes and yesOriginally posted by ReyRey@Jan 15 2009, 04:26 PM~12715183
WILL A 200R4 BOLT UP TO A 231 V-6 ON A REGAL PRETTY QUICK? FOR EXAMPLE - BOLT PATTERNS AND LENGTH.
200c and 200r4 crossmembers are different, it is the only that has to change when doing the swap though. I read somewhere 2004r and 400 trans cross are the same but I just welded mine when I swapped.Originally posted by Sleepy G@Jan 15 2009, 09:38 PM~12718909
yes and yes
and the crossmember on a turbo350 and a 200 metric and 200r4 are the same
I KNOW FOR A FACT CUZ I BOUGHT A CROSSMEMBER WHEN I CHANGED MY 200R4 TO A 350 AND IT WAS THE SAME ONE
:tears: 40 BUCKS GONE AND I DIDNT GET MY MONEY BACK
WHAT I WANT TO KNOW ISDOES SWAPPING TRANNY FUK WITH THE COMPUTER AT ALL BECAUSE ALL MY SHIT WORKS CHERRYOriginally posted by El Duez@Jan 16 2009, 02:45 PM~12725072
200-4r fits both Buick/Olds and Chevrolet.
700-r4 fits only Chevrolet.
100% correctOriginally posted by Sleepy G@Jan 12 2009, 09:04 AM~12678559
200r4's do not handle horsepower well
thats why they are mostly on turbo motors and cadillacs
(like 3 mechanics told me that)
and 700's just fit chevy motors, am i right?
The only electrical connection on the tranny will be for a lockup torque converter so it wont effect anything. If your gonna put a trans in a Monte Carlo, the only one I would use is the 700-r4.Originally posted by soldierboy@Jan 17 2009, 02:14 PM~12733675
ITS ALWAYS BEST TO PUT IN WHAT U GOT OUT. BUT IF YOU DO DECIDE TO UPGRADE IT WILL FIT RIGHT UP. YOU DONT EVEN NEED THE PLUG.Originally posted by soldierboy@Jan 10 2009, 08:07 PM~12665602
Originally posted by 83Cizzoupe@Jan 18 2009, 03:12 PM~12741180
not true, a 2004R (not R4) are used in 1000+hp applications. Read the new issue of Car Craft theres an article in there. I believe the length off the 2004R is the same length as a short TH350 so it should fit, but there is a TCC solenoid for the torque converter on the 200 that is not on the 350 and without it you may throw a check engine light and the car may not even run right. Anyway I'd rather have the overdrive than a 3 speed 350 but thats your call, bottom line is replace whats in a computer controlled car with the same thing and youll be happier
